Hi All,
I am trying to determine the best way to enable printing over WiFi. Research so far has revealed I could:
I have 2 USB connections so would leave one hardwired to my PC and use the WiFi to print from laptops. Does a hardwired connection still work after adding WiFi?
Thanks.
- Replace my router with a router + print server combination -
- Buy a print server and connect to printer via USB
- Make a print server using a Raspberry Pi (most fun option)
- Replace my printer with one which has WiFi (if it proves to be more cost effective)
Thanks.
