I have a laptop from acer. It holds this battery AC14b18j Battery for Acer Aspire ES 15 ES1-531 ES1-533 ES1-572 Laptop 11.4V 36wh.
The charger when plugged in stays at 0% if the charger is removed it goes dead. I have received a notification of a power surge on the USB port. So common sense dictates the port is the problem. There is no other port to put the charger.
I would get a replacement battery or is this an issue with the battery port? The battery port look to be solded on so would be impossible to be removed manually by myself.
I APPRECIATE ANY INPUT AND WOULD BE ETERNALLY GRATEFUL.
