I have 2 Acer E5 575G laptops. The battery in one died and I bought a replacement. After installing the replacement the battery shows 39% available, not charging. I contacted the seller who said that it may be a motherboard problem. So I took the battery from the other laptop and installed it in the one with the new battery. It shows 100% not charging. After that I put the 100% battery back into the original lalptop which was charging OK before I took it out, and it says 100% available, not charging. I have tried a battery reset, uninstalled the battery drivers and used a different adapter on both laptops. They still show 100% and 39% available, not charging. I did a fresh install of Windows 10 on the laptop with the 39% problem and that didn't help. Both laptops work when on the adapter. What have I missed? Nothing that I have done works.
