Solved A pc problem plz help
Robert Andrei
25
So my PC isn't working.
The surse is on but on full power
The monitor is off
The mouse is off
The keyboard is off
I tried to press the keys but isn't working and reset it to
Plz help
what is the PC age?
what have you tried so far, have you opened the case and removed any dust build-up?
is it a laptop or desktop?
have you tried removing the memory, cleaning it and its slot, reseating it and seeing if that helps?
what is the PC age?
Thx bro but it works now. cables ware burned
