Solved A LIMITED 'TIMED OUT' EDIT FOR ALL POSTS
Heat Sink
132
38
74
Perth
This morning I had to ask Gus to fix two spelling mistakes in a post I put up.
On most other forums, they give a 'timed out' EDIT ability to assist those putting posts up.
Can this be incorporated on this forum please?
There is an edit option which on my iPad is well hidden (don't know if it's well hidden intentionally or my iPad), click to the right of the post date within your message & edit, delete & report should appear, (you may click on the wrong one unintentionally). I can still edit posts from weeks ago. I will post a screenshot of this post to show you.
Well thanks Bastet. I now see the 'edit' at the bottom of the page. Is this another example of my 'dumb and dumber' syndrome or was that not always there? Duh!
The edit button,has always been at the bottom post, in the xenforo forum software.
Reactions: gus
Never noticed it before Gus and I am mystified why you didn't tell me to do it myself a couple of days ago when I asked you to make two spelling corrections.
As bastet said it could be clearer, but then she is just a mouse.
What makes it harder to see is that when I scroll the page up it disappears completely and then returns after scrolling each time.
Was quicker to do as you asked.
The edit command is visible when you mouse over your post, simple.:)
