4090 3d adaptive stress test 100k errors @ 5 mins using OCCT.. advice/help needed. w/ screenshots+sys info.
Thixon
42
Hi all, I ran two tests, first picture is the first one that i stopped at 5 mins, second test was also stopped at 5 mins but it got up to 100k errors when it hit 70% workload. The errors start at about 5 seconds into the test. Is this a sign of a bad GPU? my games have been randomly freezing and but still hear the audio, and then after 10 seconds the screen loads images again, or it can also sometimes just crash the game entirely. Happens in WoW and Fortnite (all I've played). Its a gigabye GPU and still under their 4 year warranty (Thank ***!!) This GPU was like 1500$ and is only 2 years old.
At this point I'm pretty sure I'm just going to RMA this bad boy but idk....
I have a corsair 1000w platinum psu, temps dont get hot, ram is new (crashes happened with old ram too), and cpu is stable from tests. this is the only error I've gotten from running all OCCT tests.
Do you still need assistance ?
Yah, updated Bios for Motherboard, GPU as well.. but just froze and crashed while playing fortnite out of the blue... dont really know what else to check or troubleshoot at this point.
Stop running stress test, if enabled disable fast boot and restore the MBs default factory settings in the BIOS then post back, include in your reply a Speccy url, see below;
Restoring the MBs default factory settings in the BIOS, they are sometimes listed as one of the following " factory defaults" "most stable" or on newer boards "optimized" please note that if you have both the "most stable" and the "optimized" options in the BIOS you should choose the most stable" option as in this instance the "optimized" settings are a form of overclocking that can cause instability.
Save the new settings, exit the BIOS, restart the computer, test by using the computer as you normally would but include doing the below;
Download then run Speccy ( free ) and post the resultant url for us, details here, this will provide us with information about your computer hardware + any software that you have installed that may explain the present issue/s.
Being that the OP revisited the forum but chose not to acknowledge my reply this thread will be closed.
