3070 FPS issue
Limbz
14
23
Hey guys I play comp Cold War, I have a 3070 , 3700 x combo and consistently get under 200 FPS on all low settings. I have overclocked and am open to core and memory clock suggestions. Would appreciate help to get up to that 200 mark
And the evga xc3 ultra 3070 tri fan, sorry not too familiar with the tech, best I could do^
This is the power supply. Should I download that run it on my pc ?
Is this a work/company computer ?
You are running Windows Enterprise.
You have avast installed - can you uninstall or disable it to test. Turn on Windows defender.
Can you change your power plan to balanced.
You are not updating windows - Auto updates are off. You need to up date.
Read through this Best FPS settings for Cold war
No it is not, the person who built it for me used a code for enterprise. Windows is upto date. I actually did disable avast this one time just to test it, it didn’t make any noticeable difference. Sure, let me try reading through that.
Read through it, my settings are identical except for the dlss as turning that on quality has ACC lowered my fps
also same game settings to check against what you have already done Click On Me
Are you plugged in via cable to the internet - Not wireless. if wireless can you run a cable?
High performance is a kind of overclocking.
guys i think i have identified the issue, my cpu and gpu % is considerably slow its is at 30% making it clear that there is a bottle neck issue. Is there a solution to get higher usage or optimize in a way where gpu and cpu are used more.
Whilst we are waiting for Evan to have a look Are you connected via network cable?
What refresh rate is your monitor set to is it 240.
Enable Game Mode in Windows 10 From Here
1. Game Mode configures a number of Windows settings with a single click to optimize your PC for gaming and maximize the display's frame rate.
2. Click the Search button and then click "Settings."
3. In the Settings window's search box type "game" and then choose "Game Mode settings" in the search results.
4. If it's not already turned on, enable Game Mode by swiping the button to the right. You might need to restart your PC for the settings to take effect.
