I played Fortnite and I was using the GeForce Optimized.What games are you playing and at what settings? Are you using GeForce Experience to optimize the detail settings?
Hello Pokesquid,
Have you checked the temperature of your CPU and GPU when playing games ?
You can do so using HWMonitor. HWMonitor can be downloaded here - https://www.cpuid.com/softwares/hwmonitor.html
Some other questions -
What PSU does your computer have?
Was this a problem before getting the 1050ti? (assuming this was an upgrade)
Have you recently installed any software or updates recently?
When I was downloading games, it said that my CPU was at 87C and my GPU was at 32C.
What is a PSU?
Hi pokesquid.
Your CPU is overheating when the temperature is this high when you not even playing a game. You will need to open your computer's case and take out the CPU cooler and re-apply thermal paste on the CPU and ensure that the CPU fan is in working order when you power up the computer again.
PSU = Power Supply Unit.
Its the device that powers all of your components on your system. If you look on the power supply it will tell you what the maximum output in watts is and we will need to know that information.
CorsairYour PSU wattage is adequate for the computer build but I would re-apply thermal paste to the CPU and ensure the CPU fan is working properly. What manufacturer made the PSU though?
\What games are you playing and at what settings? Are you using GeForce Experience to optimize the detail settings?
