cloudflare warp issue
This topic has been answered.
  • maxim123
    • Aug 2017
    • 473
    βœ… Resolved cloudflare warp issue
    Hello, I have been using cloudflare warp, but even with it disabled in startup, its warp-svc service runs during startup
    and today, even with cloudfare warp off, my domain is considered as cloudflare warp's.
    so I uninstalled it completely, then net didn't work in ethernet cable(wifi works). Edited dns to automatic(it had changed to 127.0.2.3 /4) , then net worked, but certain sites or apps like discord didn't work.
    now installed cloudflare warp again, and everything is running again.
    I would like to be able to change to cloudflare warp when I want instead of it running in background when I don't want it to. Is there a way to do it? thank you.
  • Answer selected by jmarket at 11-02-2025, 08:20 PM.
    jmarket
    PCHF Owner
    • 7700
    • CachyOS, Windows 11
    • Nvidia RTX 5070 TI (16 GB GDDR7)
    Even when Cloudflare WARP is set not to start with Windows, its background service (
    Code:
    warp-svc
    ) is configured as a Windows service that runs automatically to manage network interfaces. That’s why you still see it active, even if WARP itself appears β€œoff.”
    You have a few options to stop it from running automatically:
    1. Press Win + R, type
      Code:
      services.msc
      , and press Enter.
      Locate Cloudflare WARP Service (or
      Code:
      warp-svc
      Double-click it and change the Startup type to Manual or Disabled.
      Click Stop if it’s currently running, then Apply β†’ OK.
    If you prefer doing this via Command Prompt (run as Administrator), you can use:
    Code:
    sc config warp-svc start= demand
    That sets it to manual mode so it only starts when you launch the WARP client manually.
    When you want to use WARP again, just open the Cloudflare WARP appβ€”it will start the service automatically.
    If you disable the service entirely, the client won’t connect until you start it again with:
    Code:
    sc start warp-svc
    This setup gives you full control to toggle WARP only when you need it, without it running constantly in the background.
    • maxim123
      maxim123 commented
      Editing a comment
      thank you so much
  • maxim123
    • Aug 2017
    • 473
    from what ISP told me just earlier, it seems some public ip of the isp is having issue accessing certain sites or apps, so I guess I will have to wait for them to solve the issue. The help I want here is how to make sure warp-svc doesn't run in startup when the app is disabled.
    • xrobwx71
      • Mar 2023
      • 1068
      What operating system?
      • maxim123
        • Aug 2017
        • 473
        It is win 11 pro
        • jmarket
          PCHF Owner
          • 7700
          Code:
          warp-svc
            Code:
            services.msc
            , and press Enter.
            Code:
            warp-svc
          Code:
          Code:
          sc start warp-svc
          • maxim123
            maxim123 commented
            Editing a comment
            thank you so much
