Open Who able to help me with PC diagnosis? I have overall weird performance.
Tennobyte
13
38
Well, For the first i have these specs:
GPU - RTX 2070 Super EVGA
CPU - Ryzen 5 5600
MB - Msi B450m pro vdh max
RAM - 32GB 3200mhz 16-18-18-18-36
PSU - PCCooler GI-K800 (Basically 800 watt 80+ gold)
I have issue with sudden stuttering, lagging, bad screen recording performance.
None of components experiencing overheating or throttling. And none are causing bottleneck. (none is overloaded to 100%).
I have scanned my PC with antiviruses hella lot of times, no clues. (also tried installing pure windows on other drive, still freezing)
Any ideas? Drivers? Viruses? Faulty GPU or CPU?
Let’s do a full workup of your system.
No personal data is published and everything shown is safe.
1) Download Speccy by Piriform.
In Speccy, click File > Publish Snapshot > Copy to Clipboard > Close.
Paste that link into your post. Is Speccy safe?
2) Download GetSystemInfo by Kaspersky.
In GSI, click Start. (takes about 10mins)
It makes a ZIP file on your desktop, drag that to their GSI Parser site.
Once analysed, paste the newly created URL into your post.
3) Download MiniToolBox by Farbar.
In MTB, tick List Installed Programs, click Go then close the program.
A file MTB.txt is created in the same folder, attach that to your post.
4) Go to www.speedtest.net and screenshot your network speeds.
http://speccy.piriform.com/results/o5AzE0vDObBgA4eCNmUv1oU Speccy thing
https://www.getsysteminfo.com/report/7698e9c98ed2ec1a80f46b44da65744b Kaspersky thingie
MTB.txt thing attached
https://www.speedtest.net/result/17473578785 Speed Test
My suggestions;
You are on the limit for the power requirements for the RTX2070, see here; https://support.lumion.com/hc/en-us/articles/360003476773-Which-power-supply-do-you-need
Getting your hands on another PSU would be good to rule that unit out as potentially to blame.
Removing Kapsersky and MBAM will automatically re-enable Windows Defender, which is all the security you need these days. So if those two paid-for products are due to expire soon, I'd not renew them.
Your issue only happens while gaming?
Everything is fine if you are just reading documents, emailing, browsing, printing, etc.?
Reactions: xrobwx71
My suggestions;
Unplug the samsung drive D:/? Uhhh when did seagate became samsung? Not to mention "samsuing" mistake.
Seagate drives is fine with abnormally high Seek Error Rate values. It's their internal work shown in smart kinda.
Well, I have issues with screen recording performance and I get stuttering in Roblox Studio application (Don't laugh at me, this thing is actually my money xd).
I don't play games too often or much to say exactly, but in Elden Ring i haven't noticed such things. But the issue is uncomfortable.
I already removed Kaspersky because this crap was preventing me from downloading torrents 😶‍🌫️
qbittorrent is probably best and safe torrent client i ever knew.
what about PSU... I bought one used from some guy that builds pc's, by his words PSU was for about 1 year in use. I noticed it has foreign fan instead of original. The fan power is just straight out the case bended corner to the motherboard. (Also pretty noisy so i had to turn it to minimum i could 35%)
Anyway, zero system shutoffs.
I am not sure if its to blame, I don't have enough money for this unit currently.
Maybe It's still something else?
My bad - Seagate it is.
D:\ is the important point. :)
No drama on doing, or not doing, what you want. It is after all your PC.
My suggestions were simply that - suggestions, things to address trying to logically work through the issue and crossing off potential causes.
I'll let others chime in with their suggestions. (y)
Reactions: xrobwx71
Thanks anyway. It worth a try. I am not sure if unplugging hard drives will change the situation, because I remember same stuttering far ago when my system was on SSD and no hard drives present. Just it gets too frustrating to ignore. I will consider changing PSU later, but not experiencing troubles with it at the moment. I'll wait if someone else comes up with other ideas.
It certainly helped here. https://pchelpforum.net/threads/eve...-games-such-as-watch-dogs-2.92704/post-201844
We go through these steps to rule out each component, not guess if it's the culprit or not.
I would consider changing it now. It's a low tier PSU that is not adequate for the 2070.
What should I change it for? I am on b u d g e t.
What about drives, I have checked your link briefly, I will make investigation towards the pagefile instead as there said.
I am not sure but I will make few tests to see it. Seems that problem is in windows. No viruses and not corrupted filed however it sucks. Trying clean installed windows now on the same rig.
