Hi, I have a problem with my new PC that there is a significant amount of ram that is being used compared to the amount I'm using. For example, my user, which is the only user on the PC, is only using 6GB of ram but my task manager says it's using 13GB. This leads my PC to slow down in certain aspects. I also saw some things where you go to the Registry Editor on the computer to fix this, however, it didn't work either. Please help as I have seen in certain places that people said I should completely reset my PC, but I want to avoid doing that. I went to this forum as I wanted to ask you guys for your expertise in this situation as you're much more informed on this than I am as I'm new to this PC stuff. Below I have attached my PC Specs and my computer's actual usage compared to what my ram is using up. Thank you guys for the help!
Here are my PC Specs-
Amd Ryzen 3600 CPU
Asrock B550 Pro4 Motherboard
16 GB 3600 MHZ G.Skill RAM
Asus RTX 2060
500gb NVME m.2 SSD
2TB HDD
Amd Ryzen 3600 CPU
Asus RTX 2060
500gb NVME m.2 SSD
2TB HDD
