RTX 2060 problems
sageofthe6
3
EVGA RTX 2060 XC Single Fan
AMD Ryzen 5 2600X
GIGABYTE Aorus b450 pro
16gb Corsair Vengeance 3200 mhz RAM
550W Seasonic Power Supply
Windows 10 Pro, 64 bit
So I've had my pc for about 2 months now and everything was working great. I had been playing destiny 2, csgo, dead by daylight, fortnite, you name it, until one day I had downloaded Star Wars Battlefront 2. The game was running smooth and it looked great until I started getting these little symbols/artifacts that popped up all over my screen. The screen went black after a couple of seconds and then my pc restarted. Ever since then it has been happening to other games as well, including destiny 2, which I had taken a picture of when it happened. All of the drivers are up to date and I have tried downclocking my gpu through precision x1 and still the same thing occurs after about 15 minutes of play. I have even tried simply taking the card out and putting it back in. Is this a problem with my gpu or is there something else that has to be done because I don't want to blow the money for a new card if I am not sure that it is the problem. Thank you.
According to the specs you gave the motherboard has onboard graphics, so REMOVE the graphics card from the PC and plug your monitor into the motherboard graphic slot, reboot and see what happens then.
Took out the card and plugged in the hdmi into the motherboard and there was no display on my monitor.
Nothing comes up on the monitor when I power it on so I can’t access the bios. Just looked it up and the ryzen 5 2600X does not have an integrated gpu so I won’t be able to see anything unless it’s from the graphics card.
You can always reset your motherboard to default by removing the battery for about 20-30 minutes.
Sorry didn't realize your chip had no graphics capability. Suggest you remove your current video driver with DDU and download and install a new driver from EVGA, not get a driver through Windows. If that fails it time to test the card in another pc, or try another card in your pc.
