New PC restarts on load - Kernel power 41
MaN8fy
22
Hello everyone,
I have a problem where my gfs new computer reboots on load. Event viewer tells me that this is a critical error: kernel power 41.
CLOSER INFO
Her PC SETUP:
  • ASUS ROG STRIX B550-F GAMING
  • GIGABYTE GeForce RTX 3060 Ti VISION OC 8G (rev. 2.0)
  • AMD Ryzen 9 5900X
  • Noctua NH-D15 chromax.black
  • Kingston FURY 32GB KIT DDR4 3600MHz CL18 Beast Black
  • Samsung 870 EVO 500GB (system disk)
  • Samsung 980 1TB
  • EVGA 650 B5
  • 32" Samsung Odyssey G5
BACKSTORY and FIXES
I built the computer by myself, when I finished it, I just enabled DOCP for RAMs and enabled something for W11. Then I downloaded W11 on it and everything was fine so far. I downloaded all the drivers, updated windows, set them up. Then we just usually downloaded steam, discord, and couple of games. She headed up into the csgo, in menu everything was just perfect - so far so good. Then she started actually playing and after 2-4 minutes she got black screen and quick restart. SUS huh? Hoped it was just something random after fresh built. But suddently it happened again after 2-4 mins in game. So I started wondering what it could be I I found out that windows recognize only one RAM so I reseated them and thought it was it. Now there was both. But it happened again. I found out that there was kernel power 41 happening. I looked up for the web for common reasons and tried some windows settings to fix.
  • high performence
  • no auto restarts
  • drivers update
  • bios update
  • windows update
  • etc..
  • getting nervous
Didn’t help. Then I tried couple of HW things:
  • Reconnecting cables
  • GPU reseating
  • MB has classic 8 pin + additional 4 pin (optional) so I bought addapter 8 to 8 + 4 and tried that, also didn’t work
  • I thought its PSU problem, so I tried PSU from my PC (modular evga 650W G3) - I changed just a PS, not cables - but it didn’t work
  • so I tried another PSU from my work (600W not sure about certification) which normally runs rtx 3060 and is not modular so I had to reconnect all the cables. Didn’t work.
  • Crying over it
Now I tried clear w10 installation, downloaded all the drivers and steam only with csgo. And it crashed again. Now I am desperate and hopeless.
MORE ABOUT PROBLEM
About CSGO, it happens every time she is in game for about few seconds up to 8 minutes, never lasts longer.
Didn’t try other games yet. But actually tried some tests and benchmarks. Windows MEMTEST went good without problem, disks were fine too, GPU benchmark and PSU crashed.
ABOUT RESTARTS
So everytime this occurs it has 2 scenarios.
1) Black screen and really quick restart without even manufacturer logo. immediately get windows login screen.
2) Quick BSOD (almost even unnoticable) and "normally" fast restart.
In both cases after opening event viewer there is Kernel power 41 problem.
I have no idea what else to do. At this point I think that its not "software" issue. And its not PSU issue ( in case there is no need to buy 750, but IMO 650 is just fine). So I think it must be MB, CPU, GPU or RAMs. Maybe disks? I dont really know anymore.. For the last 5 days I have been doing nothing but assembling and disassembling the same computer over and over, testing, and failing. This is my second computer I'm building, the first I built for myself about 5 years ago with a 1060 and successfully. And its also my first experience with rtx, not sure if I missed maybe some important settings in the bios, something important in windows, nvidia.. that's why I try to be so detailed in the text. Thnaks for any help.
Unfortunately, as you said it is your GF's pc this is against rule 17. I hope you can understand this reasoning.
17. PCHF will not offer assistance on behalf of other people. This is for security reasons. This means someone posting and asking for assistance for someone else is not permitted. Thanks for reading this and let's make PCHF a great place for everyone to enjoy.
