Most crucial hardware for brute force and data processing?
Xavier Donnelly
23
What components are the most instrumental for brute force cracking and simulation/algorithm testing (avg 1.2 million variations at the end of each test). I am wanting to upgrade from a laptop I have now and build my own setup, my budget is $10,500 AUD. I just have too many mixed answers on saying what is most important from CPU to GPU and RAM. I just want to make as much processing power possible I don’t really care about anything else. Thank you for your advice in advance. PS I have already decided on the motherboard and CPU. I have attached them to this post
$10.5K is an unusual limit.
when you are wanting such critical processing power, all components become important.
in such a system, there will always be a bottleneck, you just have to decide where you are comfortable with where that ends up.
for example: slow CPU? - upgrade it, then memory is the limiting factor. upgrade that, then graphics is the bottleneck. get a SSD then you're back at wanting a better CPU. it's a vicious circle.
so to answer your question, it's the best of everything that your budget can afford.
and realising that there will always be better! :)
Reactions: Xavier Donnelly
no updates necessary unless you have further issues. :)
let's close this for now, and if you have further questions, PM any staff member to have the thread re-opened.
be aware - when you mention phrases like brute force cracking - alarm bells ring!
