maxkoll1212
24
I have an issue when turning on my pc. The asus mobo logo appears but the little circle that spins does not appear. My pc will only boot to my bios, and it says that there is no hard drive connected, however, my hard drive is connected to both the motherboard and psu (obviously) it also says that no bootable devices could be found.
Please help me
Thanks
So other can help you this information needs to be answered.
Desktop or Laptop?
Make and Model?
System Specs? Including power supply.
How old is the system?
Where there any changes made to the system just prior to this happening? What were they?
Is there a HDD or SDD?
Any sounds, beeps, clicking? Describe?
Have you tried re seating the drive to the power and data cables?
You say you can boot to the bios, check to see that your boot order/device has not changed and is set to your hard drive. Also see if you can boot to any other devices? Suggest if you can boot to other devices but not hard drive then check your hard drive power and sata cables and if ok remove hard drive and see if you can read from it from another pc. This can be checked either as an internal drive or as an external drive with caddy.
Please help me
Thanks
Any update for us?
