Solved HDD not detected
TheMetalMessiah
5
29
A couple of days ago i have used windows reset 'till than everything was fine. After system reset laptop detects only SSD. When i enter bios and go to storage properties it says that SATA slots are empty. I havent touched internal components ever.
I have used intel assistant to instal all driver but still problem persists. Tried re installing windows but it gives me only SSD available. Even in disk management HDD is not detected. PLEASE HELP im stuck with 256gb :D
Laptop in question: MSI GE73 raider RGB 8rf
just to ask the obvious - it definitely had a HDD in there?
what made you reset Windows?
perhaps the HDD has died.
under warranty?
Yeah it definitely had HDD as (D) drive 1TB.
When i would play games at random i would get a black screen and sound going on speakers not on headphones which would go for like 2-3 sec than everything would start working normal... yes its under warranty. its like 5-6 months old..
It was working perfectly fine before i have reset windows.
Thanks for your time
was there data on D:\ ?
in Disk Management is the HDD not even showing up in the bottom section as Disk 1 (or something) ?
is all you see Disk 0 for the SSD and CD-ROM 0 for the DVD ?
Yeah D: have been about 70% full..
In disk management it doesnt appear.. anywhere...
I only see local disk (c:) without CD-ROM since there isnt any CD-ROM.
options:-
  • it's died - possible but unlikely
  • it's come lose of its connection inside - also unlikely as they are screwed into place (usually)
  • it's not a typical HDD but something else, like a hybrid drive (however, both should get drivers installed directly from Windows)
have you done a Windows Update?
have you reloaded all the system drivers from the CD or the MSI website?
because failing all that, I'd be removing the back plate and put the HDD into an external enclosure a) to see if that works and b) to recover data.
Yes fully updated windows, downloaded everything from MSI website. Tried updating with intel assisstant, updated asata drivers manually. So the next step is to open the back plate and trying if the cable is lose or discinnected? There usnt anything i can do software wise?
Kinda scared to open it but there is no workshop in serbia that fixes GE73 series for some reason
it sounds daunting but can be surprisingly easy (98% of the time) :)
YouTube some videos for your model first to get an idea on how it's done.
Some back plates unscrew, some slide off, some have access panels just for the memory and/or drives.
some even are accessible via the top by removing the keyboard - bit trickier but fairly straight forward still.
you do however need to be confident with screwdrivers and removing plastic mouldings etc.
I havent done a thing. Kind of gave up on it and searched for services in Romania. And last night i turned the PC on and boom... it works fine.. D: is showing up like nothing happened... what can it be?
complete guess, but perhaps an update has finally been downloaded and installed.
but hey, take the good surprises with the bad.
computers do that, ours is not to ask why!!! :)
good to hear it's sorted and thanks for letting us know.
