GIGABYTE - GeForce RTX 3080 10 GB AORUS MASTER / LCD & RGB Fusion 2.0 issues.
jburns95
29
A buzzing question to anyone which has the GIGABYTE - GeForce RTX 3080 10 GB AORUS MASTER.
Has anyone been having issues with RGB Fusion 2.0? I understand that the software is a complete mess but have anyone over come the issue of the LCD screen on the GPU to remain with the settings that you have put or if you have set to view the Temps ect to actually update and give real time info? Any advice would be welcomed.
The first issue i had was the GPU was not even showing on RGB Fusion 2.0 but after completing the step below it worked. This gave me access to use RGB Fusion on my 3080 for the lights & edit lcd panel settings. After reboot of computer the RGB fusion 2.0 does not recognise the 3080 again unless you put the PC in sleep mode and start up again. Then this will allow you once again to edit the settings for the 3080 on RGB Fusion 2.0
Following step i have done:
Using DDU in safe mode and uninstalling driver & Aorus Engine/RGB Fusion 2.0.
Removed other component softwares (Corsair Icue ect.)
Reinstalled drivers & Aorus Engine/RGB Fusion 2.0.
Thanks
Jevon
