Bios concstant beep issue
zombotomy
33
Recently whenever i boot for the first time of the day my bios does a constant beep. even after logging in and having everything running the beep continues. once i do a restart the beep goes away. but it always comes back wether its after its been down or even when i put it to sleep sometimes. I ran a memory diagnostic no issues found. i suspect graphics or processor. whats the best way to narrow this down? graphics card is a gtx1660
OS Name Microsoft Windows 11 Home
Version 10.0.22621 Build 22621
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor AMD Ryzen 5 3600 6-Core Processor, 3593 Mhz, 6 Core(s), 12 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 2407, 2020-07-01
SMBIOS Version 3.2
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product TUF GAMING X570-PLUS (WI-FI)
BaseBoard Version Rev X.0x
Platform Role Desktop
Secure Boot State Off
PCR7 Configuration Binding Not Possible
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume6
Locale United States
Hardware Abstraction Layer Version = "10.0.22621.2506"
User Name Batcomputer\brent
Time Zone Eastern Daylight Time
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.9 GB
Available Physical Memory 58.0 GB
Total Virtual Memory 67.9 GB
Available Virtual Memory 60.1 GB
Page File Space 4.00 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualization-based security Not enabled
Windows Defender Application Control policy Enforced
Windows Defender Application Control user mode policy Off
Device Encryption Support Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not Modern Standby, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
a new BIOS version was released last month - that may help.
can you describe the beep - is it one continuous long beeps, repetitive short beeps, how many before there is a pause, if any?
Usually indicates RAM have you tried reseating the RAM and other discreate boards?
While the system is open clean any dust that is in there using the proper safety steps.
Get some cans of compressed air and blow the system clean. Make sure the system is powered off and unplugged. Remove the battery if a laptop if the battery can be removed.
Read the instruction on the can. Spray in short burst and when the can start to feel cool to the touch switch to a different can. After they warm up to room temp they work fine.
Do this in a well-ventilated room or outside this way the dust does not settle all over the inside furniture or worse you or someone inhaling it.
Do NOT turn the cans upside down, turn the system. Remove the battery and blow that our as well.
NOTE: You take the chance of wrecking the bearings of fans with the compressed air. Compressed air can actually accelerate the fans beyond their rated speeds and damage them, if you are cleaning them out with air, it is often recommended to hold the blades in place with a toothpick or other non-conducive material.
NOTE: Do not use a vacuum to clear the dust they can cause a static discharge and end up toasting the system or a components. There are also jumper on the boards that could be sucked off and then the system would be bricked.
Clean the keyboard
Put the with the laptop facing down then gently rub your hand back and forth over the keys this will knock some of the larger pieces out. Then place the system on its side and blow the keys (remember to use short burst like before) starting from the top working you way down. Heat form portable computers is released through the keyboard.
Might also check and clean the keyboard and mouse if it is wireless change the batteries for them.
