Guys please help !
I want to buy mentioned MBO ASUS TUF GAMING B450-PLUS II, because my AsRock AB350M pro4 doesnt work well with AS1000, when i connect SSD to type C port i get only 45 mb transfer max, usb 2.0, instead of around 450mb/s for AsRock mbo. My port is 3.1 but it works like 2.0, i tested usb 3.0 flash device, it works well. I tested AS1000 on 3 more PCs, works normally. Only on AsRock AB350M pro4 and one similar plus , same B350 chipset it works at 2.0 usb, i think its AsRock mbo fault, their some compatibility with B350, drivers or controllers or smthng, idk. I updated BIOS to last, not beta, P7.40, new win10 OS, drivers installed from mulitple sources including MBO site and AMD one.
Before buying new one, in this case i want ASUS TUF GAMING B450-PLUS II, id like someone to confirm to me that it will work with transfer that is normall, around 950/1000 MB/S.
So the question is: can someone confirm me that it will work like it will on this new mbo, 3.1 fast transfer, can someone test ?
Or can the problem be that i have 1 m.2, 1 HDD and 1 SSD using so they limit transfer for SSD on my current AsRock ?
THANKS IN ADVANCE FOR HELP TEAM !
