Asus transformer mini t102ha issues--auto refreshing and search and replace pop up
DanielArdon
3
29
I own an Asus transformer mini t102ha and I am having issues
Suddenly when I open any browser it starts refreshing every 2 seconds, then when I am using Word or any office program the search and replace dialog keeps popping up, and every time I click close or the X it comes right back, this to the point that I am not able to use the computer, I do not know what to do
This only stops when I unplug the keyboard
Does anyone know why this is happening? What can I do to fix this issue?
The keyboard has stuck key(s) try cleaning it with some compressed air.
With it disconnected turn it up side down and gently rub you hand over the keys this may dislodge them as well.
Do you have a spare keyboard that you can attach to see if the same thing repeats?
It different keyboard works and nothing else help and or correct the issue replace the keyboard.
Thank you so much, I just tried with a different keyboard and it works just fine, I Will try to clean the detachable keyboard that belongs to The mini tablet and see if it works again.
I have had the issue for about 8 months
What I have been doing to fix temporarily the issue is to perform a clean instalation of the OS and the keyboard and pc will work just fine for 1 week then I have to do it again in order to stop it from happening again. Have you heard something like this before?
PD. I will buy compressed air to clean the keyboard. Thank you so much for your response, it means a lot to me
