Annoying Popups
Jerry504
38
So every so often I get a popup on my screen that says "Are you still using this computer?" or something similar. Is this normal or should I be worried?
is it "Someone else is still using this computer".
if so, that's normal, and means you either have another user still signed into the PC or a shared network resource that is in use.
how often and when does it happen?
take a snapshot of when it occurs and show that in your next post.
let's get your PC specs...
download Speccy from here; https://www.piriform.com/speccy/builds
paste that link into a post.
One area Speccy doesn’t show is the Power Supply Unit, so also include the make/model of the PSU.
