144 hz Monitor problem
Persiball
12
3
30
I have a problem with a Samsung 27 "QHD Curved Monitor with 144Hz Refresh Rate. When it is in 144 hz mode it disconnects and connects back about 5-10 times in 3 minutes. The image becomes black and after a second the image appears. connected with displayport, GTX 1070 video card.
So others can assist we need more information
What is the make and model of the power supply and age?
If you turn down the refresh rate does that make a difference?
Can you post an updated Speccy url for us and we will see what if anything we can do to help.
