Solved 100% cpu and low fps when playing fortnite
Vrot
5
25
Hi,
I recently built a new PC with an i5 12400, RTX 4060 on a msi b760-p ddr4 motherboard.
I tried running a few other games like forza, overwatch, cs2 and games ran smooth as they should.
When i launched into a fortnite game my fps was spiking from 30 to 180 and the cpu usage was 100%. All game settings are on low with dx11 1080p.
I seen that these specs should get me like 180- 400 with no problem.
does someone know what could be the problem?
If the computer is a desktop can you post the brand and model name or number of the power supply (PSU).
Download then run Speccy ( free ) and post the resultant url for us, details here, this will provide us with information about your computer hardware + any software that you have installed that may explain the present issue/s.
Here is the link : click here
Not sure how you missed the above Vrot :)
Couple of things amiss there however before elaborating we need the PSU information that was requested.
Oh sorry, i thoght the speecy link shows the psu aswell.
Anyways, here is the psu info:
Gigabyte PSU 750W PFC Gold 80+ Modular P750GM
Not the best of PSUs I`m afraid as that particular range is known to have issues, the 1000W version was rated as – Tier C • Low-end and the 850W rated as – Tier F • Replace immediately which is real poor,
Can you tell us what the below says please;
Power Profile
Active power scheme: מאוזן
There are a couple of things going on in Speccy but because you are only having issues with Fortnite I will only mention the one thing for now.
You need to enable XMP as the RAM is causing a bottleneck.
This particular game being so popular is known to have such issues due to the load on the games servers etc, have you checked the Epic Fortnite FPS issues info here
It means:
Power Profile
מאוזן (=balanced)
i understand, ill enable xmp and ill check if something is different i know that fortnite fps isnt good for everyone recently.
Thanks, your Power Plan is set as it should be.
Not expecting it to cure all but I hope that XMP helps some with Fortnite.
Being that the OP revisited the forum but chose not to reply this thread will be marked and closed.
